Car doesn't start, just clicks...???
Sorry mods if this is in the wrong spot but i didn't find an "ignition" specific area.
Anywho, when i go to start the car, it will just click. The solenoid in the starter (i think) isn't getting good enough contact and just "clicking". I have to turn the key back and forth between the "on" position and "start" position kind of fast before it'll start. I have to do this maybe anywhere's from 5-30 times before it'll engage and start. It has no starting problems once it starts turning over, it's just the actual engaging that's doing it. I just got done taking out my starter (which was fun) and cleaning the living crud out of it. I took the actual starter motor off itself and then sprayed the whole gears and solenoid and everything with carb/choke cleaner until it was completely clean. Then lightly greased the gears again and put it back in there. but i still have the same darn problem as i did before It just clicks and doesn't turn over no matter how long i hold the key in the "start" position. If i don't let it prime it'll usually turn over right away 80% of the time, but it still wants to stop and click. I'm kind of lost now, help is really needed.
ShibbyZ
ShibbyZ
Re: Car doesn't start, just clicks...???
When ever the solenoid clicks it's because it's not getting enough current. Either the battery is low/shot or there is a wiring problem reducing the current to it or the switch is bad. The last possibility is the starter is bad and pulling too much current.
The obvious thing to do is process of elimination. Put a non good battery directly to the starter and eliminate everything the starter. Then go back on the wiring until the battery and leave the switch for last.
i had the same problem about a month ago, my grond wire to my battery had came loose so i just tightened it up and it started right up. also make sure the contacts to the battery are free of corrosion.
Ok, i'll check it out. So far it hasn't clicked now after i cleaned it for probly 20 times in a row. So maybe that's a good sign. *knocks on wood and crosses fingers* It did have a ton of junk in it and gum looking stuff. Kind of like it chewed some old cloth and grease together in the gears. Actually...that might explain why it's starting to work now, i took the battery off when i took it out and put it back on when i installed it...maybe i tightened it up or something. It's a brand new battery too.
My solenoid is just about shot and i have to clean it like once a month or so and make sure that it is moving in and out easily. Could be a loose cable too. I would just check cables and then try, after that i would take the solenoid of off the starter and clean it so the plunger moves in and out easily.
Checked all my connection at every possible location and i sanded them down and they have good contact. It still does it, could i possibly just need to clean the starter out more?
There's a large cable and a small cable, yes. Then there's a third from the actual starter motor to the solenoid that engages it. I cleaned those off and they're good. Could i just have a bad solenoid, which would mean i need a new starter?
I know this sounds off the wall, but do you have VATS? If so, your key could be making intermittent contact. If all else fails, or if you get tired of messing with the starter/solenoid check it out
I did clean the solenoid, i cleaned the whole dang starter minus the actual starter motor. I held the can of choke/carb cleaner down in there until it was running clear again. It's seems to be better but still does it, just doesn't do it 30 times anymore.
I have a 1994 camaro z28 LT1, we just put a new starter and alternator and battery on. All the wires to and from the battery have been replaced and fixed. The car just clicks when you try and turn it over, it will only turn over when the starter is being banged on. Could this mean I need a new starter or a bigger battery? bc I’ve went over everything and we can’t figure out why it’s not turning over right away. Any advice please let me know!!!
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
How long has it been since your car ran?
