WD-40???
I have heard WD-40 will help remove bug guts. Is there any special technique to this. I tried this today with no real luck.
------------------ Red 97 Z28, Dealer installed F1 package, Hurst M6, chrome cai with K&N filters, 3" decoma exhaust 2OTL, cut out, air foil, hotchkis stb, 17x9 ZR1's, SS hood |
I will probably remove fresh ones but so will car wash and detailer spray, I do not use it myself cause if I have to wash after its use, what is the point. It does nothing on embedded or etched bug deposits, I bet that is what you have, in that case a Clay Bar or polishing compound is what you need.
------------------ 96 Black Impala SS Authorized Zaino Showcar Polish Distributor www.zainobros.com Remember #3 |
My cousin always used WD40 on his Mustang. He thought it worked great. I tried it and I didnt think it worked very well at all. Maybe you have to leave it on so it will soak in.
------------------ 96 red Z m6, t-tops, subframe connectors, LCA's, tubular panhard rod, skipshift eliminator, K&N FIPK, BMR stb, 17"SS rims, 3" Magnaflow Cat-Back exhaust and other misc debris |
| All times are GMT -5. The time now is 02:32 AM. |
