Tree Sap.......how to get it off??
I have used clays bars in the past with excellent results on some very neglected vehicles. The lube of choice for this project is a car shampoo (1-2 cap fulls) in 16 oz of water. You will not only remove the sap but also all embedded gunk in your finish safely. A solvent (gasoline, bug and tar, xyxlene) would also work but the embedded gunk will still be present and your finish will still require a claying.
One claying step will perform both tasks.
Other than pine sap I have never seen any kind of tree sap that simply did not wash off with water and car wash, if it is tree sap you can use stuff like 3M Wax and Grease remover or Goo Gone...
I'm not exactly sure how to get it off but do it as fast as you can because my friend got that stuff all over his Eagle Talon and it just ate away at his paint. It left white spots all over his car.
Originally posted by GoFast908Z
um, not for painted surfaces, unless you like discolored paint look.
Maybe it is ok, but i wouldn't risk it. I detail cars all the time, and i've never had to resort to anything extreme like that. And I've done some cars that were in BAD shape. Claybar has always worked on the tough stuff.
