clean engine
Old Mar 29, 2006 | 05:13 PM
wakebordr2006's Avatar
clean engine
whats the best way to clean the engine without harming anything? can you use a power washer and some degresser? if not, what else?
Old Apr 5, 2006 | 12:07 AM
mccullar_racing's Avatar
Re: clean engine
I'd also like to know the answer to this.
Old Apr 5, 2006 | 07:17 AM
moparman's Avatar
Re: clean engine
I wouldn't even think about a power washer on an LT1. With the LT1, you need to be very careful around the front end, due to the opti. The LS1 is not as water sensitive.
Old Apr 9, 2006 | 02:44 PM
shock6906's Avatar
Re: clean engine
We had a guy powerwash his engine in a cadillac coupe deville, a couple thousand dollars later, he learned his lesson...
Old Apr 11, 2006 | 03:28 PM
Lil Dog's Avatar
Re: clean engine
Wrap everything you're paranoid about with tin foil, spray built up greasy areas with 'foamy engine brite', for everything else use something like 'simple green' let sit until foam disapears, rinse with hose running at a trickle, (that's very slowly), dry with towels or drive it dry...
Caution: DO NOT get foamy engine brite on your car finish.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
