Bug Removal!!
Re: Bug Removal!!
I use Stoner's Bug & Tar remover. I wet the car down, spray the entire front area and let it soak while I wash the rest of the vehicle. By the time I do the front, they come right off.
Have they been on the car for awhile??!! Sometimes for the tougher one's, Ill use some polish and elbow grease to remove them.
Re: Bug Removal!!
Clay is to remove surface contamination, if you wash your car and you feel the paint, if it's not smooth, and feels a little like sandpaper, claying will correct that, also you may feel little bumps on the surface of your paint, but your cars paint looks clean, claying will remove that and make your paint feel smooth as silk. Claying will make the light reflect better off your finish, and make whatever wax you are using last longer, it does this by making the surface flat and clean, this allows your wax to get a better hold of the surface.
Re: Bug Removal!!
Re: Bug Removal!!
i never heard of clay bars before i joined this site. after using it once i will never detail a car w/out it again. i also pefer the clay method for bug removal. i dont like using too many different kinds of chemicals on the paint.
Re: Bug Removal!!
I highly advise Claying a car...i work at a new car delaership and i even clay brand new cars with 5 miles on them...the damn Raildust and other contaminates get all over the car.
What color is your formula?
Re: Bug Removal!!
Originally posted by fastformula309 I have tried so much to get the bugs off the front of my car. Does anyone have any ideas how to get them off?
Also, when I home after taking the car out on the interstate or something where I collect a lot of bugs I will take a paper towel, saturate it with water so that it is soft and then wipe the bugs right off. This allows for me to keep the nose piece looking brand new.
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
