Anyone ever done any controlled environment documentation of multiple Zaino layers?
What I mean by controlled environment is essentially taking pics under controlled lighting - ideally meaning a well let garage where you can make sure the lighting is the same every time - but at least possibly outdoor shots where you checked to verify the clouds, sun, time, etc were pretty consistant from shot to shot.
I'm just interested to see how much of a visual difference multiple coats of Zaino makes?
I'm tempted to strip the hood of my silver Audi of the wax it has on it now, clay it, clean it thoroughly, and tape it down the middle, then do one side with a single coat, and the other side with some ridiculous number of coats. Say maybe 8 or 10. Then take pics and see if y'all see any difference.
We already did this once on my dad's red '02 F150 but only with 1 layer vs 2. I want to try taking things much further.
Predicitons on the results? Any guidelines I should be sure to follow other than no more than 3 coats of Zaino layers per day? I'll try to do this over the weekend if I get any decent response - that way I can drive my wife's car if I need to go anywhere and let the Audi sit.
Re: Anyone ever done any controlled environment documentation of multiple Zaino layer
Originally Posted by ZaneO
I think it will be hard to capture something like that through a camera.
Honestly I've never been able to tell much of a difference when 'layering' zaino - in the end I've kinda questioned whether I just wasted a couple hours and a few dollars worth of zaino or not when doing a second coat. When layering, say, 3 coats one after another... other than the supposed visual gains, will there be any noticable increase in durability as well?
Originally Posted by Threxx
The difference between zero coats and one coat is huge when on camera, so why should the difference between one and ten coats be difficult to see?
Make sure to post your findings though; it will be interesting to see.
Re: Anyone ever done any controlled environment documentation of multiple Zaino layers?
You'll find diminishing returns as far as depth and shine after 3-5 coats. The main reason to add the occassional layer is to maintain the finish and add more protection. With using the Z-8 you won't notice as big a difference after finishing off coats with it.
Maybe if you were to use a pro 11-20 mp camera, of course the problem then would be finding a monitor good enough to see the difference. We shot some pixs several years ago showing one coat vs 5 coats, that was done using an 8 mp camera, and while you could see the difference in person, you could not see much difference on the computer.
The megapixels captured by a camera, past a relatively early point, (like the point that even the cheapest camera has surpassed today) makes no difference at all on most modern day PCs, as its far higher resolution than the native resolution of that monitor anyhow. What does matter is the camera's capturing system itself, the lense, the settings used on the camear to capture, and the lighting. My boss has a Canon digital SLR camera (~$1500) with some fancy 800 dollar lense. Maybe that will be enough?
You must not be into photography/PCs much.
Probably not, my GF uses a Cannon camera with 16+ mp
I have a 6 mp camera that most of the pixs on my web site were taken with, her pixs are 100% sharper than mine.
That 1500 dollar camera just will not cut it for what your are looking to do.
You can also get PC monitors that offer much better resolution like Ultrasharp from Dell, I have one and it's some much sharper that the old TV tube type monitors of the past.
Doesn't do any good to talk theories...just show us...
Who's talking theories?
You are - theories, opinions, whatever...stop talking about it and do it, since that's the reason you started this
And regardless of the monitor vs. camera vs. whatever discussion going on, more than anything, I'd like to get your own visual opinion on it. Something like, "You know what, there is a difference." Or "I wasted my entire weekend."
Above all, If you don't mind doing it, I'd be very appreciative to see what happens.
Cheers,
Jeff
