WTB LT1 water pump drive seal tool and bose speakers.
I'm in need of the special LT1 water pump drive seal tool. My seal is leaking on my new motor and i need to replace it. I figure i must need the tool cause my brand new seal is leaking. I also need the 2 rear qtr. speakers for a 95 bose system. I think my door speakers might be on their way out too so if you have a whole set i might be interested in those too.
You guys have PM's on the speakers. Dan do you mean the coupler shaft is worn enough to have a groove and cause a leak or the actual drive inside the block is worn and causing enough movement to make it leak.
The speakers are from a 97 TA with about 60,000 when they where removed. I don't know if the bose and monsoon are interchangable. I don't have the ones from the rear seat I have the door speakers and the 4 speakers from the rear hatch area. If your interested $50 shipped, They all work great
well thanks for the offer jssws-6 but i want to use all bose stuff to make sure it works. I really only need the rear seat area speakers and i wouldn't mind some new door speakers. My car only has 2 speakers in the doors, 2 in the rear seat area and one sub in the hatch so i don't think your speakers would work for me. Thanks for your time though.
u2slo5point0
Sep 9, 2002 05:44 PM
