Timing chain cover,etc
LT1 parts
Looking for 36# injectors,ac line that runs alongside the frame and the heater hose with the 2"metal section that does the same.
Already got the timing chain&cover,thanx.
It was used 5k. The ED is extreme duty. The LT4 timing chain that came in factory LT4s is not much stronger than an LT1 set. If you are looking for strength you will want the ED set rather than the factory lt4 set. It has a much larger and stronger single roller chain.
I've got one on fleabay right now, it's at $40 with no bids
...ends in a couple of days
I see them on there every now and then, just search "LT1 timing cover", you'll find all three styles: the '92-94, the '95, and the '97-'97.
Mine's the '95 of course
...ends in a couple of daysI see them on there every now and then, just search "LT1 timing cover", you'll find all three styles: the '92-94, the '95, and the '97-'97.
