Lt1 steering shaft and accessories bracket
Like the title says ;)
The safety plastic rivets melt on mine(my fault) so i need another one. Has cheap has possible.I got a rag joint eliminator kit so the rag joint doesnt have to be mint. Thanks |
Originally Posted by always faster
(Post 5942599)
Also looking for a accessories bracket with no stripped hole(wich hold the alt,ps pump,ect)
Thanks |
Ummm...why don't you just spot weld it? I am using one that was lengthened and then welded solid.
The plastic inserts (contrary to what people tell you) were there to provide a quick indication to a body shop to determine if there was frame damage after a collision. People will tell you it will collapse upon impact, but the shaft will deform regardless of a spot weld or two. |
i have steering shaft and brackets. they arnt stripped but we can work something out
Found and payment sent.
Thank you all. |
