Like the title says
The safety plastic rivets melt on mine(my fault) so i need another one.
Has cheap has possible.I got a rag joint eliminator kit so the rag joint doesnt have to be mint.
Let me check. I might have one of these lying around.Originally Posted by always faster
Like the title says
Also looking for a accessories bracket with no stripped hole(wich hold the alt,ps pump,ect)
Ummm...why don't you just spot weld it? I am using one that was lengthened and then welded solid.
The plastic inserts (contrary to what people tell you) were there to provide a quick indication to a body shop to determine if there was frame damage after a collision. People will tell you it will collapse upon impact, but the shaft will deform regardless of a spot weld or two.
Found and payment sent.
Thank you all.
Thank you all.
