600 lift cam
i have a 94 lt1 383 stroker.im looking for like a comp cams 600 lift cam.can anyone help or know where to get one?
your best solution
CAM HELP® Phone Number: 1-800-999-0853 |
Pm me I got an LE3.2 for you. It is in the area of what you want.
i have a speced joe o cam solid roller 260-269 620-660
custom ground 600 lift , 248 , 252 dur. 112 cl 75$ charlote nc , the cam is nice and in good shape.
jimlt4383 very interested how many miles on it?
pm sent . i did not run a speedometer but i would say 3000 miles. the cam looks good. do you have a 383 or 350 ? if its a 383 what rods do you have?
just so you guys know I found out a few things.i do have the computer so the cam has to be able to work with that.Hydrolic roller cam.will be using 1.6 rr.
with a 383 and h beam rods my cam will hit the rods . i have a smaller comp 540 , 560 , 238 . 242 , 110 cl with 1.5 rockers but i think it will hit the rods too. i think you should look for a small base circle cam with the h beam rods. if it was me i would use a .950 base circle . i think a 1.050 mite hit if the rods are not clearanced a lot. good luck with your hunt.
ok this is what i need comp cams part # 07-467-8 or 07-468-8
.576 intake .584 exaust with 1.5 rr |
