6 speed trans
read a write up on how to do it, the bolt pattern is the same, you have to use the LT1 slave master and flywheel but on the flywheel you have to have the bolt holes "egged " at a machine shop then balanced, the machine work cost was minimal.
I have a race-prepped 6-spd rated at 650lbs TRQ with < 50 miles on it.
Check out:
https://www.camaroz28.com/forums/sho...d.php?t=774328
Check out:
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
