Nitrous, Nitrous, & More Nitrous
I have up for sale 3 Seperate Nitrous kits. All kits are designed for the LT1 but i don't think there is any difference in the kits except for the nitrous jets but can be bought pretty reasonably and are not included with the first two kits anyway:
1: Brand new Cold fusion 10lb EFI wet kit part number CFN-1100. http://www.coldfusionnitrous.com/EFI...?CategoryID=19
http://www.summitracing.com/parts/NEX-15607/
This is the kit... Tho what is missing from it is the nitrious fuel solenoid supply line, pictured at the upper right with the red ends near the bottle, the nitrous bottle nut which goes on the bottle and adapts down to the long nitrous feed line, the nitrous jets, and the misc electrical fittings/wiring. (this is about $75 worth of parts that are needed)
What is included is all new, Nitrous feed line, nitrous/fuel soleniods, the lines that go from the noids to the nozzle, the relay with wiring leads, WOT micro switch, a nitrous switch (not pictured), 10lb bottle and the bottle brackets. As a bonus a brand new in the box NX nitrous filter and 7 inch line comes with the kit.
$330 for this kit as is or $295 without the nx nitrous filter & line (complete kits sell for $470 and you only need $75 worth of parts to complete it).
2: Dynotune Wet EFI Nitrous kit w/purge solenoid. Complete except for needing nitrous jets and probably some wiring to hook it all up. It comes with optional purge kit, 10lb bottle, bottle brackets, custom switch panel that fits in the ash tray, WOT micro switch with bracket, lines, nozzle, relay, and some wiring.... Kit sells for $379 plus $69 for the purge kit - Asking $300.
http://www.dynotunenitrous.com/store...p?idproduct=24
http://www.dynotunenitrous.com/store...?idproduct=110
3: Harris Works Wet EFI Nitrous Kit, with purge, bottle warmer, & Trick Performance dual Window switch. This kit is comes with nitrous jets, all the lines needed, 10lb bottle, blow down tube, Wiring, Trick Performance Dual Window Switch part number 00011, custom switch panel that fits in the ash tray, Dynotune bottle automatic bottle heater with auto switch, bottle brackets & board that was setup to mount the bottle inside the spare tire area to hide the bottle, & NX nitrous filter & line extension.
This kit was $350, window switch $150, purge $60, warmer $100, & nitrous filter $60. Thats $720 total. Asking $500 as is or buy it without the window switch for $400.
http://www.harrisspeedworks.com/prod...cat=137&page=1
http://www.ottperformance.com/store/...ch-146p256.htm
http://www.harrisspeedworks.com/prod...6&cat=6&page=1
http://www.dynotunenitrous.com/store...p?idproduct=17
RUENUF
Mar 13, 2016 03:37 PM
