Pacific Alaska, California, Hawaii, Oregon and Washington
when u lower your car what else should u add to it
Old Apr 9, 2003 | 10:50 AM
kal2k's Avatar
subframe connectors? adjustable pan rod ? control arms??
anything else u can mention??
i dont plan on doing any more performance mods, i just want a better looking stance b/c rite now the car looks too high so which of these mods is a good idea for pretty much a stock car?
any input would be appercitated
Old Apr 9, 2003 | 11:03 AM
JD30thZ28's Avatar
Thumbs up
When you lower your car you don't really have to add anything else. Although to help traction it is a good idea to get Lower Control Arms and Lower Control Arm Brackets. If you gte wide rear tires then also get an adjustable Pan Hard Rod to center the rear end. Subframe connectors don't have any connection to lowering your car although they do make a pretty noticeable change in handling.
Old Apr 9, 2003 | 11:17 AM
Draco's Avatar
No need to add anything to what Johnny said
Old Apr 9, 2003 | 11:22 AM
irocz383's Avatar
Don't forget to get your alignment done after lowering...
You don't want to get uneven tire wear on tires that cost $3-400 a pop!
Old Apr 9, 2003 | 11:57 AM
silicuda's Avatar
perfect lowering job supplies & materials
-lowering springs
-adjustable shocks (KONI for example..)
-adjustable pan han rod
-lower control arms / relocation brackets
-tires re-balanced after lowering job
Old Apr 9, 2003 | 12:08 PM
SBainsTA's Avatar
from what I've heard, when you lower your car the springs are stiffer than stock. As a result you get body flex. I was told that Subframe connectors are almost a must to minimize any flex from lowering the car. I would put them on regardless, if I'm right or wrong, because the improved handling on its own is worth it.
and no I don't think it'll void your warranty
Old Apr 9, 2003 | 01:35 PM
oldschool's Avatar
I would recommend the Sub-Frame connectors aswell. Not only does it limit flex and improve handling, it also reduces squeeks, leaky t-roofs and makes your car more solid in general. I really noticed a difference when I did mine...a definate must have for cars of our power level and build quality.
Andy
Old Apr 9, 2003 | 02:28 PM
todd15's Avatar
18 inch wheels
Old Apr 9, 2003 | 02:36 PM
kal2k's Avatar
ok i guess i will get subframes, ya i've heard that if u got ttops that its almost a must to get subframes to prevent flex so thats the only other thing i will get.
where is the best place for a good lowering job that is a good price??
thanks for all the input now time to drop the sob
and sandeep ull get urs haha watch out
Old Apr 9, 2003 | 04:07 PM
SBainsTA's Avatar
Call Kris @ Superior Performance. 604-888-4881
Tell him I sent you. Ask him how much without tax if you know what I mean. He's a good guy to deal with
Old Apr 9, 2003 | 04:27 PM
LuCiFeR97Z28's Avatar
If you're running the stock shocks, it's only a matter of time before they will wear down after a lowering job. I put in some Koni SA's after my Sportline install and never had a problem. Just my $0.02 .
A.
Old Apr 9, 2003 | 04:38 PM
kal2k's Avatar
the stock shocks will be fine for a while i know of people who are and been running them for a while with the lower job without probs so ill worry about that down the road
thanks sandeep
Old Apr 9, 2003 | 11:09 PM
sleeperZragtop's Avatar
A.
Aly's right, your stocker's will over dampen..leading to a leak...beside's our cars are a pain when it comes to removing the stock springs from the shocks...that bolts is always a pain to remove...some place will need to cut the bolt or heat it up making it weaker. If your gonna do it, do it right...
Old Apr 10, 2003 | 04:31 AM
My thoughts exaclty . You're already saving some good coin with those cheap-a$$ springs - IMO put that saved cash towards some aftermarket shocks...at least some SLP revalved units...
Mike is right...ya might as well kill two birds with one stone .
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
