What Next?
Re: What Next?
Originally posted by 85MustangGT
After a bigger carb what should i do next on my stock 79 350?...
The usual first step is intake and exhaust. SID has the common sequence pretty much nailed. Your driveline ( I assume its a th350/8.5") will be strong enough for a while. Depending on what rad you have I would also recommend a larger one, and/or electric fans.
