Pacific Alaska, California, Hawaii, Oregon and Washington
? on installing subframes
Old Apr 23, 2003 | 08:43 PM
phil94-T/A's Avatar
I have a welder....I have some subframes....now the question I have is can I install the subframes with the car up on jackstands?
The jackstands will be positioned under the rear end, and under each A-arm. Is it feasible????????
Thanx
PHIL
Old Apr 23, 2003 | 09:11 PM
SBainsTA's Avatar
I beileve so. Just watch out for the fuel lines on the drivers side when welding
Old Apr 23, 2003 | 09:14 PM
CoryM's Avatar
Sure can... If you dont mind getting sparks in your face. you could also borrow some ramps for the front. Those steel car ramps are known to collapse BTW. I dont use them. The solid rubber or plastic ones are supposed to be pretty good though.
Personally I wouldnt bother straightening the chassis before doing SFC (unless you want things to be perfect) as the unibody will still twist and flex a little even with the SFC. I would however get the unibody straight before doing a cage.
Good Luck.
CoryM
Old Apr 23, 2003 | 09:24 PM
JD30thZ28's Avatar
Thumbs up
As mentioned won't be a problem it will be level enough.
Watch out for the fuel lines
Old Apr 23, 2003 | 10:03 PM
sleeperZragtop's Avatar
Hey Phil...I could help...and do mine at the same time
Old Apr 24, 2003 | 12:20 AM
mr_muff's Avatar
i should buy some and then we can all do it at once, im sure one of us would be able to get a lift for a couple hours. it is a fairly easy job is it not if we could get a lift?
oh yea i forgot i have no money :/
can we wait a month and a half
hehe j/king
Nov 18, 2023 07:21 PM
HOFFICER
Apr 6, 2020 10:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
