How to tune out rear O2's with hp tuners ??
Have any of you have done this ?? :confused:
Re: How to tune out rear O2's with hp tuners ??
Yes very easy.
You'll want to go through the DTC list and find all sensors of both bank 1 and bank 1 that are labeled as Sensor 2.. Sensor 2 indicated the rear sensor
You will want to leave the DTC On/Off flag as it is, but will want to set the error mode to "No Error Reported". :) |
Driver Side
137 - Ho2s Circuit Low Voltage Bank 1 Sensor 2 138 - Ho2s Circuit High Voltage Bank 1 Sensor 2 140 - Ho2s Circuit Insufficient Activity Bank 1 Sensor 2 141 - Ho2s Heater Performance Bank 1 Sensor 2 420 - Catalyst System Low Efficiency EDIT:some people do not have to disable this code, I did, results will vary. Passenger Side 157 - Ho2s Circuit Low Voltage Bank 2 Sensor 2 158 - Ho2s Circuit High Voltage Bank 2 Sensor 2 160 - Ho2s Circuit Insufficient Activity Bank 2 Sensor 2 161 - Ho2s Heater Performance Bank 2 Sensor 2 430 - Catalyst System Low Efficiency Bank 2 EDIT:some people do not have to disable this code, I did, results will vary. |
i just did a quick search on hptuners website and thats waht keith says to do.
http://www.hptuners.com/forum/YaBB.p...num=1099721785 http://www.hptuners.com/forum/YaBB.p...50;start=11#11 |
Amit, I already posted what he said, why are you posting?
done deal thanks guys :)
omg, are you CRYING? :cry: |
