Gotta love torque
Originally posted by NiteRider
I got my shoes to slide on the pavment, i'm sure they put down around 5ft lbs of TQ.
The way your car drives in rain is no way to measure torque, now if you could do the same thing on a dry road you got something there
but with your shifting
It sucks after a long dry period because all of that damn oil over the roads turns the streets into an ice rink.......
Originally posted by 97TA-WS6-Con
Well all I know, is that I looked at my dyno sheets and I'm pretty sure none of you guys has 390# of torque at 2000 rpms.
Also I wasn't shifting into fourth I was cruising in fourth and then gave it a bit off gas. Either way i wasn;t expecting to get a wiggle on and it was kind of fun.
However, I have to agree with Payam Joun, that doing the "wiggle" in the dry is the only way to justify a new name.
while u have to wait for ur hairdryer to "spool up with rpm" ... i can get a garuanteed 300 extra ft/lbs at 2000 rpm with the push of a button
.. now all i gotta look at is my NA ft/lbs at 2000 rpmbut last time i checked .. noone his the dyno at 2000 rpm
so im surprised u have a 2000 rpm reading on ur sheet .. must be them americans
just buggin ya man ..
Originally posted by Tw!tchb!tch
I gotta slip that says 560 rwtq @ 3000 rpm muhahahahaaaa !!
... and on the 5th day, god says, let there be blower... it was useless till he hit 5000 rpm, then he had to shift not to overspin it.. god uninstalled his blower and put the NX kit back on
Originally posted by sideways_Into_3rd
I bet u anything i'll have way more than 390 ft/lbs of torque if i unleash my monster at 2000 rpm
Dude, if you hit the button at 2000 rpm with anything more then a 75 shot, one of two things will happen. A Nitrous backfire will blow off your intake manifold, or you will detonate and bend a rod.
pfft .. nah !! those are just a myth .. none of that will happen
