Pacific Alaska, California, Hawaii, Oregon and Washington
Anyone know where i could rent a fender roller?
Old Jun 18, 2003 | 12:47 PM
StreamlineZ28's Avatar
just wondering before i try and mickey mouse something to fix my problem. i need a fender roller
Old Jun 18, 2003 | 01:41 PM
1999V6's Avatar
What's your problem, im guessing you got new tires and mags and their rubbing?
Old Jun 18, 2003 | 01:50 PM
the inside lip of the rear fender rubs when i go over some bumps
and it is annoying. it doesnt really don anything but i dont want it to cut into the tire so i want to bend it flush against the inside. it probably would of done it with the old tires but they didnt go out far enough.
Old Jun 18, 2003 | 01:52 PM
sideways_Into_3rd's Avatar
i might end up having to do that for my new slicks
wont a hammer do the trick ?
let me know how u gonna do urs .. im absolutely clueless when it comes to body work !
Old Jun 18, 2003 | 01:58 PM
1999V6's Avatar
Is it your rear right tire?
Old Jun 18, 2003 | 02:02 PM
yup most of the time it is the right rear
payam if i cant find a fender roller im just going to cut the lip about every 2-3 inches and tap it flush with a mallet. then i'll paint the inside where i cut with under coating so it doesnt rust.
you have to cut it cause it is round like the fender so if you just hit it with a hammer it will ripple the fender. also i'll have to use a heat gun probably so it doesnt crack the paint.
i also need to get an adjustable pan hard rod, probably next check.
Old Jun 18, 2003 | 02:06 PM
1999V6's Avatar
If you don't want to do that you can get a adjustable panhard rod, it will center the rear end for you. I notice you have lowering springs so maybe it's the best way to do it, it'll eliminate the right side lean that you have.
Old Jun 18, 2003 | 02:25 PM
1999V6's Avatar
I bought my new rubber and my rims are coming in so I have to do this too. Just called mopac in surrey, talked to a guy who own's a lowered 95 red ta. Adjustable rod costs $180.00 and figured it'd be a hour install.
Old Jun 18, 2003 | 02:49 PM
JD30thZ28's Avatar
Thumbs up
Just grind that lip off
Old Jun 18, 2003 | 03:35 PM
have you ever had any problems with your wheels and tires. or is that what you did.
Old Jun 18, 2003 | 03:44 PM
JD30thZ28's Avatar
Thumbs up
I didn't have any problems with the outer lip. I had to bend the inside of the wells in on mine and also cut off the Bump Stops. Although on Perry's convertible the outer lip was rubbing and we grinded it down which resolved the problem
Old Jun 18, 2003 | 03:58 PM
if you grind it down doesnt it leave a sharp edge that could cut the tire.
Old Jun 18, 2003 | 05:18 PM
JD30thZ28's Avatar
You can smooth it down to leave an edge just like it has now
Old Jun 18, 2003 | 05:21 PM
mabye i will do that then seems like it would be a bit easier then my way. and i shouldnt have to worry about paint cracking or the fender rippling.
Old Jun 18, 2003 | 05:23 PM
CoryM's Avatar
To roll fender lips alot of guys just stuff a peice of wood on top of the tire and turn the wheel (slowly). I dont know if this would work in your case or not.
CoryM
