Pacific Alaska, California, Hawaii, Oregon and Washington
Adjustable Shocks... help!
Old Jan 31, 2003 | 11:43 AM
silicuda's Avatar
I need to lower my car sooner or later, to give it a bit more of 'quality handling'.
I have a question and need your guys opinion... I do not know too much about shocks, but I know that my mechanic recommended I look for adjustable ones. I called Mopac and also Lordco and of course they told me the 200 dollar a piece shocks are the best..
Are there any adjustable shocks that are like 50-100 bucks each that will fit fine on my bird?
Old Jan 31, 2003 | 12:26 PM
Tw!tchb!tch's Avatar
Koni single ajustable are what Im going to run . I spent some time talking to Sam Strano and alot in the autocross and road race forums and there an awsome performance shock for around town / autocross use etc . You can get revalved bilsteins but if you swap your springs your going to need a revalve again which is more $$ . There about 1100 from mopac , 730 usd plus shipping from www.stranoparts.com which is very reasonable when you consider the shocks are the most important part, and are by far the weakest link in the f body suspension .
Old Jan 31, 2003 | 12:29 PM
Do you have your drop springs yet ?? Im selling my eibach sportlines and going with ground control adj coilover setup, if your interested let me know . . . . They should fit no problem .
Old Jan 31, 2003 | 12:31 PM
silicuda's Avatar
TB: I am probably going to get the Einbach Pro Kit 1.25" drops in rear/front...
... how much are u selling the shocks for? will they fit my v6 firebird
Old Jan 31, 2003 | 07:59 PM
sideways_Into_3rd's Avatar
im selling my sportlines too u can have 2 sets of springs for extra .. springability
$730 usd plus shiping OMG !
first off, $1100 from mopac is cheaper !! and goddamn !! im paying $650 + ship usd for a full set of HAL shocks AND springs ... though the hals are more for drag racing . they are 12 way adjustable AND have front ride height control !!
damn konis are expensive !!
Old Jan 31, 2003 | 08:40 PM
94Zman's Avatar
You could go cheap with adjustable KYB's ..... but I have not heard great comments on them. Might sell my Suspension Tech springs ( 1.2/1.7 drop ) if you are not in a rush ( I'm waiting on Bistein's )
Old Jan 31, 2003 | 08:44 PM
OneFlyn95z28's Avatar
Guys do not fool your selfs on the QA1 stuff! It is NOT just a drag race setup
Unless you are doing Track days the QA1s are perfect. Last time I went out on my QA1s it took a seasoned every race driver on races rubber to beat me on my street tires
I am running a stock front sway bar and a 25mm rear. QA1 springs front and stock in the rear. front shocks on 11 and rears on 6.
It was down right controlable at full tilt in the corners. I could go in ***** out and the car wouls tart a full four wheel push under heavy Throttle. all you had to do was push till then and lift some to keep your line
I was VERY happy and VERY supried!
Just think I have a new set of Nitto 555RIIs coming for this season
Old Jan 31, 2003 | 09:06 PM
nice to hear that ellis
im pickin up a set of HALs .. and im gonna be cruisin on 315 555Rs .. only if they made the 555RIIs in 315 i'd be getin those ..
should be an interesting street setup
i got a 25 mm rear bar too .. cept my front one is that 32mm u sold me ...
Old Jan 31, 2003 | 10:10 PM
Im keeping the stock shocks, I put all my factory peices in boxes so I can return it to factory condition when / if I sell it
Old Feb 1, 2003 | 11:53 PM
pmatch1's Avatar
kyb agx shocks
Hi silicuda
After hearing what people say about kyb I am afraid to say I have them on my94 z28. Although I drive my car an average of 4000KM/YR, I have had no problem with them. In fact I think they are quite kick ***!!!! When I fly up the Slocan Valley on a summer morning to the Blue Moon Saloon I pull some pretty good g's. You really don't know what its like to own a Camaro until you have lived it the Kootenays. Getting back to earth, if you drop your car more than 1.5" will it affect any warranty on your shock. Also consider the price of the install and alignment. I once read an article on a few tuner F-bodies and the best g's were on Konis and nothing else. No springs,bars,control arms,etc. I did not want to pay for Koni so I got KYB. Also consider the weight of your car. Try the Tire Rack or Year One for KYB.
My mods are-Firehawks 275's on Sabler 17''C.L. Hurst Shifter, Home Made Ram Air, K&N Filter Charger, Air Foil, Removed MAF screen, Gold Race Rocker Arms, Hypertec Power Programer, y-pipe, cat ?, Edelbrock cat back, strut tower brace, 5 point frame connectors, Harness bar with 5 point harness, KYB AGX Shocks. Hawk pads, Ford Dot 3 brake fluid.
THUS A GREAT CAR FOR THE KOOTENAYS.
P.S. Any boby else from my area. I do PDR and paint touchup????
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
