94 Z-28 Turbo
8 Attachment(s)
A good friend of mine finally decided to sell his camaro that he built that I've been wanting for some years now. He sold it to work on his new car project(s) and I couldn't pass up the deal. I plan to use the car as more of a show/leisure car.
ENGINE LT1 built by PAS Lunati Forged Crank Lunati Rods Lunati Street/Strip Camshaft 3 Angle Valve Work Port Matched Intake Stock Bore Kit 9.0 Compression Ratio HD JE Pistons HD JE Rings Clevite HD Race Bearings Felpro Head Gasket Hypertech 160 Thermostat T.B. with Airfoil T.B. Coolant Bypass Mod Taylor 8mm Wires DRIVETRAIN Stage 5 built by XP Racing B&M Deep Transmission Pan GM 3.42 Posi Unit POWER ADDER ProTurbo Charger Kit installed by ProTurbo T66 Precision Turbo .96A/R Dual Spal 10in. Push Fans 2 Water Tanks Tial 50mm Blow Off Valve 1 ¾” 4 into 1 Headers Fully Coated 2 ½” Crossover Pipe with Flex Section Tial Billet 38mm Wastegate Custom Water-to-Air Intercooler Teel Marine Pump for Intercooler 4” Intake with 4” K&N Cone Filter Air-to-Air Heat Exchanger Under Front Nose 3” Downpipe Dual NOS Fogger Nozzles NOS Purge System Edelbrock Billet Aluminum Bottle Bracket FUEL SYSTEM 36lb Accel Yellow Injectors Walbro 155 liter Fuel Pump in Tank Adjustable Fuel Pressure Regulator Begl Boost Sensitive Fuel Regulator ELECTRONICS Autometer EGT Probes in Cyl. 5 and Down Pipe Autometer Boost/Vacuum Gauge Autometer Air/Fuel Gauge Autometer EGT Gauge Autometer Fuel Pressure Gauges Autometer NOS Pressure Gauge Digital Voltage Gauge Turbo Timer LT1 Stock Engine Management Tuned by Mike Murillo PAC 200 AMP Circuit Breaker Relocated Optima Battery BMR Battery Relocation Kit BRAKES Willwood Superlite 6 Big Brake Front Disc Kit Willwood Rear Heavy Duty Pro Series Brake Kit Willwood Hi-Temp 570 Degree Racing Brake Fluid SUSPENSION BMR Adjustable Torque Arm BMR Subframe Connectors and Crossmember BMR Torque Arm Xtreme set at -1 Pinion Angle BMR Control Arm Relocation Brackets BMR Panhard Rod Relocation Kit BMR Lowering Springs BMR Front & Rear Sway Bars V-Band Clamps and Ball Joints Adjustable Front & Rear Shocks STEREO SYSTEM Kenwood KVT 719 DVD Player Dynaudio 6.5 4-Speaker System in Front Polk Audio Momo Carbon Fiber 5.5 System in Rear 2 10” JL Audio Subwoofers in Trunk Well 3 1-Farad Capacitors in Parallel 2 Boss Digital Amps Pac 80 AMP Circuit Breaker PAINT & BODY Custom Painted by CD Design 2-Tone Black and Cayenne Red 24k Gold Leaf Separating the 2 Colors Molded-in Ground Effects Center Exit Exhaust System Shaved Door Handles Lamborghini Door Kit Tonau Cover for Rear Seats Rear Camaro Letters Filled Trunk Key Hole Filled Antenna Hole Filled and Replaced with Internal Antenna INTERIOR Painted Black Interior Carbon Fiber Instrument Cluster and Door Inserts Seats Upholsted in Black Leather with Dark Suede Inserts Windows Tinted 5% Windshield Tinted 35% Attachment 3131 Attachment 3132 Attachment 3133 Attachment 3134 Attachment 3135 Attachment 3136 Attachment 3137 Attachment 3138 |
Re: 94 Z-28 Turbo
Nice ride and well done you got there. Got a Gem
| All times are GMT -5. The time now is 01:07 AM. |
