CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   Window Switch setpoints (https://www.camaroz28.com/forums/n2o-tech-23/window-switch-setpoints-439165/)
357LT1 Mar 21, 2006 10:45 PM
What are you guys setting your WS for you nitrous setup? I currently have it to start at 3k and off at 6.2K. Can I start it sooner? Can I turn it off later and do I want to? Thanks!
Ramiro
Bow94z Mar 21, 2006 10:49 PM
Re: Window Switch setpoints
i'd say leave it at 3k, then depending on what you shift at and your rev limiter is set at you adjust accordingly
Firehawk_Dude Mar 21, 2006 11:10 PM
And by "adjust accordingly" I would assume a few hundred RPM before shift point???
357LT1 Mar 21, 2006 11:13 PM
OK 3k sounds good! So if I shift at 6.8K, 6.6K is a good cutoff point?
Bow94z Mar 21, 2006 11:17 PM
yea sorry i failed to mention that, figure he would just think that;)
Firehawk_Dude Mar 21, 2006 11:18 PM
I figured... just making sure everything is crystal clear :-)
357LT1 - yes, 6.5k or 6.6k
BlownF1 Mar 22, 2006 06:55 AM
I run mine at 2800, with a 2500 stall...
357LT1 Mar 22, 2006 03:54 PM
How high do you take it up to on your stroker?
BlownF1 Mar 22, 2006 06:57 PM
I currently have it set to shut off at 5800, but that's a bit early I think. I've yet to get everything dialed in and set where I want it, but I'll plan to have it shut-off around 6200, and shift at 6400-6600 eventually.
Firehawk_Dude Mar 22, 2006 07:19 PM
Where does your 383 stop making power at with that setup?
BlownF1 Mar 23, 2006 06:19 PM
I couldn't really tell you at this point. The first time on the dyno, the trans went. The second time on the dyno, it wasn't building more than 3psi of boost due some sort of restriction in the intercooler system. Still haven't sorted that one out.
Firehawk_Dude Mar 23, 2006 09:24 PM
Got ya. Well let us know when you get that beast up and running on a dyno
TMoNeE98 Mar 24, 2006 01:30 AM
2500-5700
Firehawk_Dude Mar 24, 2006 10:45 PM
TMoNeE98
2500-5700
What's that?
