Will she blow??!!
Will she blow??!!
Do you think running a 150 shot of nitrous on my motor(mods below) with Keith black hypereutectic pistions with H beam forged rods and a scat cast crank will stand up to the task? I will do the Full throttle switch with an window switch and have it tuned by a shop for a corect air/fuel/nitrous mixture. I just sunk about 4 grand into my build up and dont want to do it again.( It was alot of yards mowed
I would have to say it would be fine to run on that engine, unless you raised the compression way up. If you are around the stock compression you will be fine. I have been running 150 shot for years with no problems.
I would change to a colder plug either Autolite 103 or the NKG's (sorry, I don't remember which NKG plug).
Joe
Joe
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
