why wont my car run good from a roll on N20?
Old May 31, 2003 | 06:00 PM
funina91ss's Avatar
I went to the track lastnight and my car dont want to shift (OBD1 BLUES)so I tried taking off on motor and then flipping on the arming switch and it didnt kick in untill I got into 3rd and didnt pick up much mph or et. If I hit it from a dead stop it goes like mad, went from 1.81 to 1.66 on the spray. I have never felt it runs good on the spray from a roll. I raced a turbo civic with a interga motor from a roll and he keept up with me then I raced him from a stop and put 6-7 cars on him Any ideas?
150 shot
bottle heater
purge
255lph pump etc.etc.
Old May 31, 2003 | 06:22 PM
Tofus 93Z28's Avatar
juice
more info,,,, hows the solenoid circuit wired....what factors open it?
Old May 31, 2003 | 06:24 PM
funina91ss's Avatar
I have a arming switch and when I run it from a dead stop I turn on the switch then I have a WOT switch to activate it. I also have a fpss. when I try form a roll I just keep it off the floor or I flip the switch at wot.
Old May 31, 2003 | 06:40 PM
so its not kicking on from a roll? if its working from a stop but not from a roll.. there is only two places to check, your fpss and the wot switch..... eliminate one at a time and see if you can rule out which one is the culprit... regardless of gear or where you are in powerband, when the jug kicks in you should know it...
also how do you have the circuit wired.. are you using relays, and im assuming the reference is any key on 12v source...
Old May 31, 2003 | 06:46 PM
funina91ss's Avatar
it kicks in but not untill later a few sec after I activate it. I have it on a relay on switched 12v.
Old May 31, 2003 | 09:15 PM
Hawk's Avatar
short the FPSS, mine gave me problems such as hesitation.
Old May 31, 2003 | 09:38 PM
funina91ss's Avatar
I have always wanted to try that but Kinda affriad of what might happen I do have a walbro pump wit less than 7k on it
Old Jun 1, 2003 | 11:46 PM
Ed Blown Vert's Avatar
I agree. Try that first.
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
