CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   Where to put fogger nozzle w/ Vortec intake elbow? (https://www.camaroz28.com/forums/n2o-tech-23/where-put-fogger-nozzle-w-vortec-intake-elbow-442828/)
camaro81 Apr 5, 2006 06:54 PM
I was about to drill and tap a hole in my intake elbow for my fogger nozzle when I remembered that this thing has a divider all the way through the elbow. No matter where I put the nozzle, it'll be directed into only 1 of the 2 blades in the throttle body.
Will this create nitrous distribution problems inside the intake?
It may sound like a dumb question to some, but I'm new to nitrous and dont wanna tear my stuff up :P
LT-7 Apr 5, 2006 11:28 PM
Re: Where to put fogger nozzle w/ Vortec intake elbow?
I think a plate setup would be best with the vortec elbow. I have the same one and plan to use the NX plate.
Ok4thGen Apr 6, 2006 02:26 AM
I dont think a plate would work with the vortec elbow,
i ran a plate tnt kit and had ALOT of trouble getting the stock rubber elbow on the car.
camaro81 Apr 6, 2006 06:41 AM
I have a compucar plate that I'm replacing with a fogger nozzle because of various problems. The plate is pretty dang thick and barely fits, I had to grind a lot off my thermostat housing and I still have a vacuum leak past the plate and it just doesnt seem to run right when I spray it.
I was told a fogger nozzle is a little better since it gives the mixture more time to atomize and is a bit better at distributing it.
I have to give it a shot though. I'm gonna try putting it on the passenger side of the elbow right in the inside of the curve so it sprays diagonally towards the passenger side. If I have any problems with one side running leaner than the other, I'll just have to buy a new intake elbow.
OffspringZ28 Apr 6, 2006 08:33 AM
nx has an LT1 plate? damn ive been out of the game for a while
LT-7 Apr 6, 2006 11:12 PM
O! I mean nitrous works.:D
nosfed Apr 10, 2006 08:46 PM
I just ordered a Trick Flow elbow for mine and it seems to fit. Haven't had the blower hooked up so I can't tell you whether there are any other problems.
