where on the back of the fuel rail do i take stem out and hook fuel line for n20?
i found one thing on the fuel rail, and its screwed in, and its a steel hose then runs into the "warning fuel" or w/e with a bigger hose
Re: where on the back of the fuel rail do i take stem out and hook fuel line for n20?
there is a test port for fuel pressure behind the intake. There should be a cap on it, take it off, remove the schaeder and screw your line on
now new problem, got that...fuel flows through...gets to noid
(didnt remove any lines past the noids) and nothing sprays thruogh the nozzle that goes on intake...
nitrous or fuel, but it clicks
You did #7 in this pic right? http://shbox.com/1/fuel_rail_94-97.jpg
Sounded like you took off the lines from the fuel rail kind of
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
