what do i need to convert a dry kit to a wet kit.
what do i need to buy to convert my dry kit to a wet kit..
this is what i have so far: Two braided main lines 15 lb bottle w/ a super high flow valve Pressure gauge Custom made flexible blow down tube Bottle Warmer Purge Valve All necessary lines after the mains Two Solenoids One Fuel pressure increasing Solenoid 14 Jets in varying sizes Msd Rpm activated window Switch Full Throttle Switch Fuel Pressure Safety Switch Extra Nozzles what do i need to buy.... a fuel silinoid, lines and a nozzel? |
Re: what do i need to convert a dry kit to a wet kit.
im not sure why you are buying stuff you dont need to convert. the main difference in a wet vs dry system is the addition of fuel into the nozzle.
so you need 1 or 2 new nozzles, 1 or 2 braided lines (based on number of nozzles), a fuel solenoid, a t fitting for the fuel solenoid (if running 2 nozzles), a 4an steel braided line to feed the fuel solenoid, jets for n2o and fuel, and if you want to do it right bigger injectors, afpr, and a better pump. |
| All times are GMT -5. The time now is 09:31 PM. |
