SpeedZ28 |
08-28-2008 10:27 PM |
You should read the stickys at the top of this thread, they explain quite a bit. The more safty devices you use the better obviously, just depends on how much money you have. As far as pulling the timing, it really depends on the brand kit you have on what they recommend but the overall rule of thumb seems to be that you should do 1 degree for every 50 hp shot. Zex seems to say that you only need to retard if you are using a mod chip or have a performance flash, so like I said, decide on a kit and then read there instructions and that should give you your answer. Good luck.
