Timing and RPMs
Timing and RPMs
In the upper rpms would the nitrous need more or less timing, and would this help your et if there was a way to vary the timing? Would a small second shot (50hp) on top of a 125 shot need to retard the timing even more? Thanks.
Any time you add more nitrous, it's better to play it safe and pull some additional timing. Typically, a motor requires less timing at higher rpms due to the fact that it is operating more efficiently while at those higher rpms. There are some gains to be made by retarding timing at higher rpms without spraying the motor.
if you pull 6 deg out that should be fine for both stages.keep an eye on your knock count with a datalogger to make sure.im on a 100 dry shot with 38 deg at higher rpms and i just run unleaded 100.your prob going to just have to try it.maybe go with 50/50 blend of race gas and pump gas on the first pull just to make sure,if its ok then try it on pump gas.
edman
Jan 22, 2015 02:45 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
centric
Aug 15, 2002 09:04 PM
