Switch Panel Wiring
Switch Panel Wiring
I installed my kit today, all I have left is to hook up the switch panel. I have 2 wires running into the car now, one is from the WOT and the other is from the Purge. Everything else is relayed, so the WOT wire should go to the arming switch which will hook to a 12v ign power source and then grounded. The purge wire should be connected and given power from the arming switch, right? Another question, the back of my arming switch has 4 prongs on it (3 in a row, one by itself in the corner). Does it matter which prongs I use for certain things?
If anyone has a diagram or anything like that, I'd appreciate it. thanks.
http://www.nitrousexpress.com/Instru...witchpanel.pdf
you didn't mention what kit you're using....but i'll assume it's NX.
NewsBot
Mar 30, 2015 12:40 PM
