CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   Stock lt1+ N2O (https://www.camaroz28.com/forums/n2o-tech-23/stock-lt1-n2o-882104/)
1775.Z28 Apr 7, 2015 12:02 AM
Stock lt1+ N2O
Hey guys, I have a '97 z28 with no mods. Just curious as to what, if anything, I would have to do to my car to be able to run N2O. Also, what size shot would be safe to run?
If you post suggestions, please provide a website with details or links to the products. Thanks!!
Injuneer Apr 7, 2015 09:16 AM
Re: Stock lt1+ N2O
No problem with 125-shot on the stocker.... that's conservative, some will say 150 HP. You will need TR6 plugs, and if you run a dry shot, pintle style injectors. An MSD box (e.g. - Digital 6), will help insure healthy spark, and can incorporate things like timing retard and a spark cut rev limiter, rather than the factory PCM's fuel-cut limiter.
https://www.msdignition.com/Products...n_Control.aspx
I ran the NOS-5176 dry kit for several years with no problems. A lot of people don't like the dry kits, but I liked mine. Not sure if NOS still makes the 5176.... I bought mine back in 1995. I'm still using some of the components in my current setup.
1775.Z28 Apr 7, 2015 03:13 PM
Re: Stock lt1+ N2O
Hey, thanks for the comment. What system is better to run? So i guess what I am asking is what system delivers most power and easiest to set up? Wet or Dry?
Injuneer Apr 7, 2015 04:09 PM
Re: Stock lt1+ N2O
Here's some good, basic info on nitrous for the 4th Gen LT1:
New to Nitrous?
