CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   Spraying 95 z28 (https://www.camaroz28.com/forums/n2o-tech-23/spraying-95-z28-882840/)
95z28man7 Jul 22, 2015 04:00 PM
Spraying 95 z28
Hey guys this winter I'm tearing down my 95 z28 lt1 and I'm going to build it for spray I'm going to go with all new bottom end 383 stroker kit bigger cam stock heads just bigger valve springs and titanium locks what size cam would be best for spray also the car is auto but I have a powerglide with a break and 3800 stall I'm going to through in the mix
Injuneer Jul 22, 2015 04:24 PM
Re: Spraying 95 z28
"Sticky" at top of N2O Tech forum:
https://www.camaroz28.com/forums/n2o...torial-520713/
95z28man7 Jul 22, 2015 10:20 PM
Re: Spraying 95 z28
Will the stock rear end hold together with 33 spline axles and 4.56 gear
streetbad Aug 16, 2015 10:58 AM
Re: Spraying 95 z28
I believe to install 33 spline axles you would need a bigger rearend.
