spray=head gasket
The first one I used was a felpro. When it blew I went to hadwin white a local idiot dealership. and got a GM gasket. I replaced them. I did it in my front yard. I put it all together. It cranked up sounded good. I was adding water. I kept on adding. Then I checked the oil. I had water in my oil. Hadwin white gave me the wrong head gaskets. I was pissed. They ended up giving my new ones. Still wasnt happy because it was a job. I changed them again. Everything was fine. I just bought some more felpro ones. Hope fully they will hold.
I was spraying 150
I was spraying 150
Moroso, the oil pan selling guys sell solid copper ones they say that those can't be blown but there around a $100 a set and you can reuse them 4 or 5 times.
Fel pro use to sell these super thin cyl. head gaskets that were only .009 inch thick ( thats = to about thickness of 15 sheets of paper) and had a compression volume of 3.2cc they cost about the same as regular ones too.
