CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   specific headgasket for n20 (https://www.camaroz28.com/forums/n2o-tech-23/specific-headgasket-n20-578290/)
94TEALz Feb 6, 2008 12:47 PM
Built a 355 set up for nitrous and just need to know if there is a specific headgasket i should run? a part number would be great. Also was wondering if the sbc arp head studs will work on the lt1? or is there an lt1 specific batch?
rskrause Feb 6, 2008 04:05 PM
Lots of people have leaks using studs on LT1's. I can't think of why the LT1 would differ from any other SBC in that regard, but it has been commonly reported (do a search). How much nitrous do you plan to run? The FelPro 1074 was fine on mine with >20psi + 200hp shot, so it should be fine for you.
Rich
InsuranceGuy Feb 7, 2008 03:23 PM
I'm also using the FelPro 1074 without any problems but you
might check out the COMETIC head gaskets. They claim
you do not need to o-ring the block/heads even under
high boost w/nitrous applications....prevent water
leaks also.
93Z,383,Vortech,NOS,water/methanol
jerminator96 Feb 7, 2008 04:24 PM
leaks also.
I hear the finish on the block/heads has to be really good for them to seal properly. No necessarily a bad thing, but if you already have everything out of the machine shop.:shrug:
rskrause Feb 7, 2008 04:49 PM
~1/3 of the time I have seen Cometics used they will seep.
rich
nxfirebird Feb 8, 2008 07:11 AM
if you get studs the block must be finished honed with a torque plate and studs, studs distort the cylinder walls greatly besause they have a much higher clamping force than bolts.
if you use a Cometic you must have the head and block surfaced just for them, and be very clean when assembled.
to be honest though, as long as everything is square, a standard performance gasket like the 1074 will hold unless your going to spray above 400+ hp.
Ray@NitroDaves Feb 8, 2008 11:26 AM
I have used both the Cometics and the Fel-pros....no issues from either.
Bersaglieri Jan 20, 2010 09:58 PM
When do you recommend heads studs over head bolts?
-Dustin-
