Solenoids
I need new solenoids, how do I know what size to get? Also, can I get solenoids from any company or only the company I got the kit from...last thing...where is a good place to order solenoids from??? Thanks Jason
You can use any sylnoid you want or rebuild the ones you have. as far as ordering some check out the sponsers
Can you use another companies rebuild kit or does it have to be the same company?
I would say the same on the rebuilds.What ones do you have?
You don't want to mix and match rebuild kits from diffrent companies. The solenoids are all built to diffrent specs.
I have Compucar solenoids right now...are there different size solenoids that I need to worry about?? If so I have no idea what size to get. Mine is the wet kit with 125 jets. New to nitrous..any info would help really. thanks jason
