Schrader valve fitting size
Old Dec 14, 2007 | 09:20 PM
93camarochrisz28's Avatar
Post Schrader valve fitting size
what size it the Schrader valve i want to hook up a fuel pressure gauge and dont know the size of the fitting
Old Dec 14, 2007 | 11:51 PM
Boosted_Z28's Avatar
The fitting is a -4. Be sure to remove the schrader valve first, if you are going to connect a -4 line to the fitting.
Old Dec 15, 2007 | 09:41 AM
remove the little pin on the in side of the valve
Old Dec 15, 2007 | 03:00 PM
97s10ondubs's Avatar
Does anyone know where to get a replacement? When I got my nitrous kit off my friends car I had to give him the valve that goes in the fitting. They look the same as a tire valve, but dont know if the seals on that would break down because of the fuel.
Old Dec 15, 2007 | 11:06 PM
Chopstix's Avatar
just get a 4an cap if you can't get the correct insert.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
