Rubber hose for purge ?!
Im going to use a rubber hose to route my purge line from the noid to the front of the car, then a hard plastic T, and 2 copper lines after the T to shoot the nitrous out
would using a soft rubber hose for nitrous purge have any ill effects ? i know nitrous can freeze the line and make it brittle .. but its only a 2 second purge !?? what are ur ideas ?! |
Just use the little nylon tubing. That will work. Thats what comes with the Nossle systems.
Kyle |
noone has any complaints ?!
i guess it just might work then :D |
3/8" rubber vacuum hose was what the NX manual said to use. It kept freezing and busting apart, went to SS line from purge sol. into a T and out the cowl.
