CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   Plugs for Nitrous ??? (https://www.camaroz28.com/forums/n2o-tech-23/plugs-nitrous-439892/)
zulu723 Mar 24, 2006 08:33 PM
What would be the best plugs for an LT1 that will be getting nitrous shortly, as I want to do them once ???
30th TA 0219 Mar 24, 2006 09:08 PM
Re: Plugs for Nitrous ???
Ngk Tr6
camarokid24 Mar 24, 2006 11:14 PM
I use autolite 104's gaped at .040. You are gonna want to pull the plugs after your first quarter mile run to make sure you have it tuned right. :)
johnny3986 Mar 24, 2006 11:58 PM
Where do you get the autolite 104's??
scottslt1z28 Mar 25, 2006 12:01 AM
gap them at .035
ThunderRacing.com.................NGK tr6's
DONT get iridium..........stick with copper
LUCIFER2 Mar 25, 2006 12:16 AM
i used to use tr6 but recently switched to tr55 you get more out of these for motor passes and they are also good for nitrous
1racerdude Mar 25, 2006 12:18 AM
No exotic metal and gapped at .035.
2fast97z Mar 25, 2006 12:46 AM
tr6's all the way...tr55's are usable
Injuneer Mar 25, 2006 01:18 PM
Just how much HP is the engine making without the nitrous, and how much nitrous are you planning to spray? That will determine what plugs you need.
Bow94z Mar 25, 2006 04:54 PM
So the TR6's are not a real good daily driver plug w/ with ocasional spray?
Are the TR55's good for a 100 shot?
97SS0594 Mar 26, 2006 01:39 AM
im spraying a 250 shot (more this summer) will the tr6's be ok?
RedTtop6spd Mar 26, 2006 09:02 AM
After reading this thread, maybe someone could come up with a reference chart for what heat range spark plug should be used for what levels of n2o. Stock motor and if feeling ambitious different levels of built motors as well. Harris Speed Works, Matt, feeling ambitious enough to perhaps add it to your spark plug reference chart?
Built LT1 Mar 31, 2006 06:28 PM
I hope I am thinking of the right brand, bit I thought Zex is comming out with a new plug. I have ran stocker non platinum autolites and Denso Iridiums. Has anyone heard that these are the best?
