Please help me
I wired up my kit the other day as follows:
Pin 30 Fused to Battery Pin 87 to the Soelonoids which are then grounded. Pin 85 to my Throttle Switch, Window Switch power (red), Arm Switch (12v Ign) Pin 86 to the other Window Switch wire (orange wire - mallory) This is my problem. The relay seems to not be getting any fire. When I turn the Arm switch on (wired with Window and Throttle) and touch it to the battery post, the window switch turns on. When it is hooked to the relay, nothing happens. When I touch the soelonoid and the fused battery wire together, I hear them click. I know the relay isnt bad because this is my second one. When I leave 30 and 87 hooked up and put 85 to power and 86 to ground, the soelonoids click but still no window switch. Any suggestions on what I have wrong? Thanks for your help in advance. |
Screw the relay, just bypass it.
