platinum plugs and 100 shot wet kit
thinking about a wet kit, only 100 shot as i am on stock internals, with bolt ons...do you guys suggest fuel pump? what size? injectors? what size? and if i should definitly change my plugs...what kind?? thanks a lot and please feel free to inform me more in depth of your opinion on thew wet kit.
Re: platinum plugs and 100 shot wet kit
yes, new plugs are a must! Platinum tips will be lost after a good squirt of N2O and then you will have some serious problems! Fuel pump is not reguired so long as you know your stocker works. have a FPSS just in case. I ran a 150 shot on a bolt on car up to 130,000 miles with a stock fuel system, before i lost a piston (my own fault).
So there is no way to run the platium plugs? The reason I ask is after my header install I had a couple of plug wire boots touching the headers and the only way I got around this (besides taking them back off and beating in the tubes
) was to run the Accel shorty header plugs, which are a double platinum plug. I found that they make a colder version of that plug thats in the same heat range as the NGK TR6 but still a double platinum plug. I am getting eveything together to install a NX wet kit 75-150.
all the accell shorty plugs i have seen were copper plugs,no platinum.
the cylinder pressure and temp gets hot enough to melt the platinum tips off the plug and they could possibly hang up on a seat of a valve and cause problems.
re route the plug wires if they are too close to the headers. i run NGK TR6 plugs with hooker long tubes and i run Taylor 409 race wires (10.4mm) and they dont touch.
CobraEatr
Jul 22, 2002 09:49 AM
