NX jetting for 300 shot
Need response ASAP!! I need jettin size for a wet 300 shot Iceman kit.....
E-mailed NX, but they haven't got back to me.. Fuel Pressure?? Thanks, -Scooba |
Can I buy you block after you've holed a piston I need a block to build a stroker.
<font face="Verdana, Arial" size="2">Originally posted by jgoodman: Can I buy you block after you've holed a piston I need a block to build a stroker.</font> ------------------ '93 Z/28 M6 3.73's_6point cage_orange with yellow pearl_RK sport GFX_SS hood_RK sport hi rise wing_clear corners_billet grille_ported heads/intake_5 angle perf. valve job_97'LT4 383 by SELF RACING_CALLIES stealth crank_OLIVER six inch rods_J.E.forged dished pistons_10:1 compression OLIVER splayed mains_custom grind cc306_LINE BORED_BALANCED AND BLUEPRINTED_FASTCHIPS custom chip and ED Wright DYNO tune_EGR bypass_home made SFC's_home made short throw_home made LCA's_home made CAI ------------------------- Eibach Pro kit_ET Streets_Hooker ceramicoated LT's W/true duals and "H" pipe_Taylor Spriro wires_Autolite 104's_Aeromotive adjustable FPR_30# injectors,58mm TB, 1.6 comp pro magnum RR's -------------------------------------------------------------------------------------------------------------------------------------------------------------------- WEAPON OF CHOICE: NX wet 200 shot |
A 90 N2O and 50/55 fuel should get you there with 1000psi N2O and 40psi fuel.
Try around 55 first on the fuel just to make sure you're not too lean. ------------------ SSMOKEM 1995 Impala SS "Cherry Bomb" Best ETs: faster than my '65 pickup Mods: 93% stock My Super Impala SS Website |
