Nitrous System Wiring
This thread should help with basic wiring questions, if any unique diagrams are needed please let me know.
Base single nozzle system https://www.fquick.com/images/vehicl.../382158514.jpg Single stage, FPSS, and MSD window switch https://www.fquick.com/images/vehicl.../382158515.jpg Single stage. purge, our digital window switch, FPSS, and 12v timing retard https://www.fquick.com/images/vehicl.../382133881.jpg |
Zex and Mallory 685
https://www.fquick.com/images/vehicl.../382158512.jpg Single stage, FJO Progressive, FPSS, and TPS activation https://www.fquick.com/images/vehicl.../382157201.jpg Single stage, MSD window switch, FPSS, Trans brake/2 step https://www.fquick.com/images/vehicl.../382155670.jpg Single stage, LS1 Timing Tuner, our window switch https://www.fquick.com/images/vehicl.../382147031.jpg |
our 4 button switch panel...System, Purge, Heater, and Remote Opener
https://www.fquick.com/images/vehicl.../382146684.jpg |
Great diagrams Ray. I noticed LS1tech has a sticky with these kinds of diagrams. Maybe we can get this stickied here too as this does come up quite frequently.
:thumb:
Thanks Ray! |
definately agree, sticky!
what about the single stage with the mallory 685 , fpss,bottle heater ,and purge.
Originally Posted by scarface007
(Post 4800682)
https://www.fquick.com/images/vehicl.../382146684.jpg the violet wire from the 685 will connect to the FPSS and pin 85 on the relay the yellow wire from the 685 will tap into pin 87 |
Ray, I just got the FJO controller, do you guys carry the solenoid driver module?
Thanks, Jody J. |
(Post 4800682)
https://www.fquick.com/images/vehicl.../382159564.jpg Heater, https://www.fquick.com/images/vehicl.../382159565.jpg |
bump
Is it possible to make this a sticky?
Ray, is there a way I can get a hi res sent to me of these wirings? Thanks, Jody J. |
Sticky please.
this saved my ass earlier, a google search didnt help.it turned out that i had a bad relay ,from dyno tune nitrous systems ,ebay, but i was trying to trace the relay wires,and this was exactly what i was looking for.
Ray, on post #2 on the 3rd diagram with the t-brake single stage, where is the 2 step actually wired into that? i didnt see that anywhere on the diagram
| All times are GMT -5. The time now is 12:50 AM. |
