Nitrous safe????
Nitrous safe????
I have the engine set up as listed below with all forged internals etc, the only thing i did not do is 4 bolt mains which i now wish i would have. i have been considering spraying 75-150 shot and was curious on opinions if the engine would handle it fairly reliably as long as there is a good tune and no detonation. the ring gaps are currently .023-.024
I cant speak for the ring gap, since i am not sure. But with the bottom end you have i would say your are more than safe to spray that 150 shot. People shoot 150 on stock bottom ends all the time with 2 bolt mains and good results.
Then hit it with a 100-150 shot and go low 10's. Sounds easy, doesn't it.
i have been trying to work on it since i went to the track last, i have added adjustable shocks, relocation brackets, panhard bar, different rear springs, different gears, and will be adding drag radials as well. i wont use the nitrous much, probably more on the street than anything,
i have been trying to work on it since i went to the track last, i have added adjustable shocks, relocation brackets, panhard bar, different rear springs, different gears, and will be adding drag radials as well. I wont use the nitrous much, probably more on the street than anything,
I think in the end, you will need the TA and a set of DR's that have some sidewall to them. Get that puppy to launch, hit it with the juice once you hit second gear and then try wiping the smile
off your face.
As stated before the durability of 2 bolt vs 4 bolt is more RPM related than HP.
I would assume the LE3 is making peak power in the 6500+ range....nitrous will not have to be shifted as high it will need to me NA. So you should be fine w/around 150 shot.
please let me know if you have any other questions
RUENUF
Mar 13, 2016 03:37 PM
