NItrous question help
Hmmm.... is this a trick question?
You have a WOT (wide open throttle) switch that makes sure you're at WOT for the nitrous to flow. If you let off the gas, you're not longer at WOT, so the nitrous doesn't flow. That's what that switch is for.
Dave
Dave
Wouldn't you want to use the throttle switch with the push button? I've got a clutch, so I'm adding another microswitch to the clutch to be engaged before N2O. That way, both WOT and the clutch will have to be activated... no spraying between shifts that way.
Could cause a lean out. Any N2O will expand under pressure which will not be good during a decel which would reduce the pulse width to the injectors leaning out the sys. N2O should only be used at WOT. Never anything less.
Originally posted by zuluman13
But what i mean is if you let off the gas quickly will there still be a little n20 going in and cause detonation
