CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   Nitrous Plate Throttle Cable Bracket Relocation (https://www.camaroz28.com/forums/n2o-tech-23/nitrous-plate-throttle-cable-bracket-relocation-756175/)
Meen95z Jun 3, 2010 11:23 PM
I have lt4 intake with a nitrous outlet plate and 58mm bbk tb. Do I have to relocate the throttle cable bracket for the added thickness of the plate? I had a nitrous works plate before and didnt need to and dont have all the hardware to relocate the bracket with the nitrous outlet plate?
Mr_Bond Jun 3, 2010 11:35 PM
Yes you will.
Meen95z Jun 3, 2010 11:38 PM
I cannot re-adjust it and reset the tps to where it needs to be? The problem is not only do I not have all the hardware, the screws are too short.
Chris@NitroDaves Jun 9, 2010 03:52 PM
Did you buy the plate used?? If it was bought new the extension brackets should have been in there.
