Nitrous Plate Throttle Cable Bracket Relocation
Old Jun 3, 2010 | 11:23 PM
Meen95z's Avatar
Question Nitrous Plate Throttle Cable Bracket Relocation
I have lt4 intake with a nitrous outlet plate and 58mm bbk tb. Do I have to relocate the throttle cable bracket for the added thickness of the plate? I had a nitrous works plate before and didnt need to and dont have all the hardware to relocate the bracket with the nitrous outlet plate?
Old Jun 3, 2010 | 11:35 PM
Mr_Bond's Avatar
Yes you will.
Old Jun 3, 2010 | 11:38 PM
Meen95z's Avatar
I cannot re-adjust it and reset the tps to where it needs to be? The problem is not only do I not have all the hardware, the screws are too short.
Old Jun 9, 2010 | 03:52 PM
Chris@NitroDaves's Avatar
Did you buy the plate used?? If it was bought new the extension brackets should have been in there.
HectorM52
Jul 30, 2017 11:46 AM
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
Mar 13, 2016 03:39 PM
edman
Jan 25, 2015 02:41 PM
bandit383lt4
Dec 21, 2014 09:12 PM
