CamaroZ28.Com Message Board
-   N2O Tech (https://www.camaroz28.com/forums/n2o-tech-23/)
-   -   nitrous issue (https://www.camaroz28.com/forums/n2o-tech-23/nitrous-issue-864001/)
camarolover97 May 17, 2012 01:55 PM
nitrous issue
The problem im having is, whenever i use nitrous on my car it work great. It's when i give it gas to drive normal my rpms climb rapidly and i have to tap the gas pedal to get it to go back to idle.
Any ideas on why its doing this, i've also checked to make sure the nozzle is pointed in the correct direction.
Thanks, George
Injuneer May 18, 2012 11:05 AM
Re: nitrous issue
Is it possible the nitrous solenoid is leaking?
camarolover97 May 18, 2012 11:49 AM
Re: nitrous issue
i didnt know that could play a role in why it's doing this. I'll check it out , i figured it was the throttle body.
thanks for your help.
George
Injuneer May 18, 2012 05:19 PM
Re: nitrous issue
If the nitrous solenoid leaks a bit of nitrous into the engine, its just like more air flowing in. If the solenoid is leaking, it will feel cold to the touch.
If you are leaving your bottle open when you aren't using the nitrous system, don't. The constant pressure will break down the solenoid's elastomer seal.
camarolover97 May 19, 2012 12:02 PM
Re: nitrous issue
oh ok i did not know that. Then im 100% sure thats the problem because whenever im done using it. i turn off the system and i crack open the nitrous solenoid line to purge when i get home, because my purge solenoid isn't installed yet.
thanks again, George
