most n2o to use on stock ls1?
i was wondering what was the most (safe) amount of n20 you used on your cars. ie how big the shot was...how many times it was able to be use, any problems? thanks!
Re: most n2o to use on stock ls1?
like a...12 shot?
You're gonna have to pay to play. If you don't upgrade things you'll either blow your block on the first hit or you'll have to go with such a low power shot that it won't even be worth it.
Crabhart, I doubt that is the case. I don't know what size shot you can run without retarding timing on an LS1 but I seriously doubt you can't run 50 or 75 safely without any timing adjustments.
- Z28WannaB
- Z28WannaB
99TransAmWS6
Feb 3, 2015 08:27 AM
