Introducing The Nitrous Outlet 93-97 LT1 Specific Nitrous System
Introducing The Nitrous Outlet 93-97 LT1 Specific Nitrous System.
After many hours of product testing we have designed the LT1 Nitrous System of the future. This system is the safest, best fitting, and most tuner friendly LT1 system on the market. From newly designed solenoids to prefabricated stainless hard lines there is no other system on the market that can offer the same sexy looks and reliable horse power.
Unlike other brand nitrous systems out there our system is truly designed to fit your application. Other companies use universal solenoid brackets and have braided hoses lying all over the top of the engine. This Nitrous Outlet system comes with specially designed hardware so that you will not have to order special fittings or different length hoses for a custom looking install.
Our LT1 Specific System includes the following Features.
1. Newly designed high flowing solenoids built to work with today’s fuels.
2. The highest flowing, best atomizing and best fitting Nitrous Plate available!
3. Custom designed solenoid mounts.
4. Prefabricated Stainless Hard lines.
5. Precise fitment fittings.
6. CNC machined fuel feed with Prefabricated Hard line.
7. Bolts on using all factory equipment. (Including cold air box)
8. Wide range of accessories to work in conjunction with our nitrous system.
9. Capable of supporting Horse power levels up to 400 HP!
We are currently taking pre orders.
Sale is good for the month of August. Expires 08-31-09
You can place your order by calling 1-866-648-7637 or 254-848-4300
Special introductory price is 599.00
Thank you for your support.
Note: These pictures are from Mock up. Finished products will be anodized. Installed pictures will be posted later. PLEASE EXCUSE THE UGLY INTAKE
The kit comes with the bottle, bottle brakets, lines, fittings solenoid bracket, etc....all the major accessories are still extra.
You can also buy the parts to retrofit an existing Nitrous Outlet plate kit.
slomaro, this kit has been out for a while now. They changed a few things and the hard lines are a nice addition. This plate kit rocks!!
bought the complete package with every safety option available, the accessory package showed up today and the bottle and plate shows up tomorrow!!
Smart man, the only other thing I can recommend is a better fuel pump. The stocker might be ok for a real small shot, but I wouldn't trust it if I were you. That and make sure your a/f is ok. Would'nt hurt to pay for a few pulls on the dyno with a wideband.
I am now doing a complete engine build (H+C, n2o) and have an older n2o kit that I was going to use with the the plate system rather than a nozzle.
Based off the results i have seen nitrous outlet's plate setup is the way to go for a wet kit.
Is this the kit your running?
Looks good Brady. I have by 685 box almost in the same spot. No back seat so mines farther back. I also bent up a small piece of metal to raise it up a little and put a small computer fan under it to help keep it cool.
