Inside of tail pipes are white??
Re: Inside of tail pipes are white??
I wouldnt worry, its usually just when you ran it really lean it melted a bit of the piston skirting which turns white when it burns.
I have no clue, but i thought id scare the hell out of you
The white is more than likely the cause of the lead they put in the race gas. the residue plugs cat's and kills O2's so dont use it too much. I would run unleaded race gas if you have either.
The odds are it's not a lean condition causing it, unless you drive to store and work everyday juicing the snot out of ur car. Most likely a by product of the gasoline you used. I can't say I've ever seen a exhaust turn white from running lean a couple times at the track, not without seeing some parts of ur engine chillin out at the bottom of ur oil pan...
